1 - 20 of 30 Posts
2 month ago I bought klein cable cutter J 63050, just used a few times, got a little chip on the blade, I complained about it, they replaced it for me for free.
then last week I used it cutter 25mm2 copper wire, the blade got a few chips.
I complained again, they promise to replace again, also klein USA want a sample of the wire that I cut, I sent a sample to them.
it's a normal copper wire that is popularly used in new zealand, 25mm2, just little solid.
my foreman used his cutter ( "hero", a Japanese brand, very cheap) to cut the same wire, nothing happened.
anyone can give me some ideas?
Coffee drinking member
I have the 63060 cutters and they have worked fine the last 5 years. I just don't beat them by cutting quickly.
I've had those for about 10 years, the blades still look pretty good. A little deformed, but not chipped.
They say that they are for wire up to 2/0. I find it hard to cut wire that thick and break out the ratcheting cutters to cut 1/0 or thicker.
DIYer4Life said:
I've had those for about 10 years, the blades still look pretty good. A little deformed, but not chipped. They say that they are for wire up to 2/0. I find it hard to cut wire that thick and break out the ratcheting cutters to cut 1/0 or thicker.
That because Klein used to be a good product.
These days their new stuff is crap
Homer to Jebus
Electron Flow Consultant
Had a pair of Klein loppers. Dumped them for Channellock loppers. I've used the Kleins for up to #1 and they chipped. Switched to Channellock and no problems so far.
1 - 20 of 30 Posts
