1 - 3 of 3 Posts
Welcome to the Forum!
Sure have, use the web mesh to pull the stans through and pull back!
Tape it up....
Yes. For really hard pulls, I weave tie wire through every other cable and get about five feet of tie wire at each end and chinese finger it another three feet back really tight. Then tape my wire sticky side in. Tape the grip sticky side out so it can tighten, then the whole thing back over with another layer sticky side in starting back to front. A swivel helps too. I have slipped it off on hard pulls just using the taped on grip. Double upped tie wire for really hard pulls. I prefer the staggered set screw pull heads for tough pulls. Some have hollow set screws you can drill through and use right size bolt to fit in allen head and nut on opposite side.
1 - 3 of 3 Posts
