Interesting situation. A client with a rental property brought me his 3 year old "scrapped" Kohler 14RESA propane generator, which another Kohler tech replaced with a new unit. The client showed up and took possession of the "scrapped" unit the tech was otherwise going to haul away. The other Kohler Tech claimed the generator threw error codes, had the oil level too high, and then ran low on oil, etc. I tore the "scrapped" motor down and when I took off the valve cover, I found the rocker arm pivot bolt was loose, and the rocker arm was out of position (see photo.) Everything looked clean inside, and neither the pushrod nor the valve were bent. I lined it up, tightened it down, and the "scrapped" generator now works like a charm.
Questions:
1) when a rocker arm comes loose under load, what else would typically get damaged?
2) looking at the parts, is there any way of determining whether the motor was running at the time the rocker came off the valve?
3) how would you approach the client with this information?
Thanks.
