Hello! I am completely "unhandy" and looking for a little help. I had a ceiling fan installed a few months ago here in Las Vegas. And it works perfectly fine. However, when the fan is on and I turn it off by the switch at the wall, the light (which is off) will flicker on for a split second- very quick. But when I turn the fan off with the remote, it does not do that? Also, if the fan is off and I cut the power at the switch, it does not flicker? Everything else seems fine, when I turn the light on it does flicker for a split second before going on, but I figured that was normal. The remote dimmer works fine. Also, the switch is just a normal switch, not a wall dimmer. I'm worried the house will burn down and am ocd-ing badly. Could really use some help. Thanks so much!!
Edit. I apologize, I just realized this forum is for actual electricians. Thought it was an open forum. Admin please delete. Thank you again
