1 - 8 of 8 Posts
Hi guys,
First time post here. Im troubleshooting a customers LED channel letter sign and have a question about the driver. Intial problem was dim light. System is about 7 years old outside. Upon inspection, found led modules with some nonworking leds, some working and all dim. replaced all leds with new 12v .72w 2 mods(3leds) per ft, about 75 ft. system still dim. traced back to driver and found that under load that driver was only producing 6 v with 120v at input. removed driver and found not under load it produces 12 v. My question is, is that normal. I did order a new driver, $48, which is, btw, dc 12v/5a/60w. I believe that is fine for this led setup. Would appreciate any input plz. I did visually inspect wiring and didnt notice any problems.
Thanks in advance.
Jim
RIP 1959-2015
Hi guys,
Thanks in advance.
Jim
Hello Jim Welcome aboard..:thumbsup:
Sounds like a good idea just to change the driver.
This is all new stuff so I don't know much about it, however it seems that the drivers do not last as long as the LED'S themselves..
I noticed right away that the driver wasnt even warm, normally they are quite warm. Also, Im not sure how the driver interacts with the LEDs. driver fails = causes leds to drop off or fail due to fluctuations in... Or Leds fail and cause drivers to fail, not sure why that would happen, but never know.
Electrical Simpleton
I'm with Harry.
The drivers don't have the same lifetime as the LED's.
Pete
p.s. Welcome aboard!:thumbsup:
Some cheap SMPS's work on a very simple principle of delivering a preset
amount of power to a circuit.
provided that the load is stable in current draw,
then this system works fine.
So your particular unit is delivering a preset amount of power,
But it's not enough, probabily due to a faulty component,
like a worn out electro.
If voltage is fine under no or very light load,
And voltage is too low under load,
Then it's simply not delivering enough power.
Faulty ! fix it or replace it !
Pool Shark
162 Watts total is what I came up with. Some suggestions would be to replace the low voltage wire with nothing smaller than 14 AWG shielded, AKA alarm wire. Check if 24 Volt is optional.
1 - 8 of 8 Posts
