1 - 4 of 4 Posts
Has anyone come across a problem with 7 or more LED light on and the remote for the garage door does not work as a Hz generated by the LED's creates a dead zone for the door openers. i have tried 2 different brands of LED's in a house and find the detached garage door opener 60 feet away and the other openers in the are do not work when the LED's are on.
Has anyone found a fix for this as I have 38 LED's installed at one job!!
· RIP 1959-2015
Are you sure it's the LEDs ?
Have you tried regular lamp and it works?
Easier solution to double-check: turn off all the LED lights.
The driver circuits in the LEDs can cause interference. A higher quality LED bulb/driver could solve this.
Removing only the LEDs near the garage may help if it wouldn't be too extreme.
A bit of googling indicates the interference could be fixed with ferrite chokes or line filters at the LED fixtures. Higher quality LED drivers should have these built-in but cheaper ones might not do an adequate job of filtering the interference.
1 - 4 of 4 Posts
