1 - 17 of 17 Posts
Anyone installed any LED recessed lighting in a remodel job???? I just go tasked to quote a 15 lighting fixture job that will replace existing fixtures with 4 inch recessed LED lights that are going to bed dimmable. I have no clue how much these fixtures are going to cost and would I be better off getting a remodel can light then buying the LED fixture or just buying the whole thing assembled? Thanks
· Moderator
Estwing magic
The only one I have done so far was Halo 4" trims inside Lithonia remodel cans and Cooper dimmers. No problems. The dimmer almost went down to zero but had to be switched completely off. There was a momentary delay in start-up. I don't know if that is common or not.
· Moderator
Estwing magic
You may want to check into Eiko...they seem to be gaining in popularity and are at a similar price point to the Ecosmart Line. Unfortunately the Maestro Dimmer will not work with the 4" Kit, but the Diva, Ariadni, and several other Lutron Models will. Here is a Spec Sheet on the 4" Kit and Dimmer Compatibility.
I don't mind suppliers being on this forum as long as they provide information only. It isn't a venue, however, for selling stuff. So far, you are behaving yourself, WLE :) .
I try! ;)
If you want to PM details on the blue shower lights I will reach out to a few people and see what I can find. You could always just give the designer a can of spray paint!
1 - 17 of 17 Posts
