1 - 2 of 2 Posts
Hi,
I've just started playing around with some LED strips from Hitlights and like them ok, but am wondering about other options. The ones I got will do a few chase patterns and let you make some colors of your own, but they don't do multiple colors in the strip itself or a chase pattern like that...all their chases change the entire strip. Can anyone suggest a company that makes affordable strips with more options?
Also, can anyone suggest good items to cover them with like something that lets the light shine through but diffuses it a bit?
How about better ways to attach them to a ceiling than with the sticky stuff on the back? Half the time with the Hitlights the sticky doesn't stay on the strip but instead comes off with the backing, and even when it stays on the strip it doesn't hold even an 18" strip to the bottom of a wooden cabinet.
Thank you for any help!
David
I have been buying from Hitlites and have had good luck with them. My first experience was installing the tape light that the homeowner had purchased from Hitlites. I then researched and could not find a better option, so I have been buying the the high output version and using the cool white only.
1 - 2 of 2 Posts
