1 - 2 of 2 Posts
Bidding a coffee/wine bar and haven't ran the LED tape in a commercial setting. Two questions. It will be run on the bottom of uppers running over three sinks. Does it need to be run on a GFCI circuit? This question I was also curious about for a resi kitchen I have where the uppers are above the sink. Secondly can I run low voltage wire in the wall or does it need to be armored? Thanks haven't ran low voltage in a commercial building.
NJ-IEC
I would check article 210.8 (A) and (B).
But as far as I can tell the GFCI protection would not be required.
1 - 2 of 2 Posts
