:sleep1:Had a customer request all Leviton Renu plates EVERYWHERE in his house. They're screwless snap on decora cover plates.
They are junk... don't ever agree to install them. They easily take 3 times as long to install, and they still don't look that great. Worst part was they don't even work properly with leviton quickport data straps.. the strap is too thick, and the plate sticks out from the wall.
I really like the Lutron screwless plates, but the customer didn't like the crack between back plate and the front snap on.
I believe those were the onesDid it have 2 pieces to the back plate? Those are the P&S.
Yea that does suck, maybe thats how they come now? Like I said the ones I used where kinda test units so they could have changed for the worse.Oh sounds better. The ones I bought come with a back plate that you have slide over the device, and then screw the device down over it.
Sort of confusing to explain, but a really poor method. I have some extra plates, I should take some pictures of the shoddy-ness of the design.
Probably much better if you buy the devices with the back plate built into them.
lol those are a pain especially if the sheet rock is cut too large.FrunkSlammer said:Maybe this helps explain my gripe a little better... Just doesn't seem like a solid system. It's hard to tighten the receptacles so they're strong, because you eat up the plastic on the back plate. Seems to work okay for switches.. and terrible for any kind of plastic strapped device (low voltage).
