Many more fixtures.
Many more fixtures.I need to install new light fixtures in a 45'x90' pole barn The rafters are 12' above the floor and the light needs to be sufficient to work in.
I figured 48" t8 lights with 4 lamps per fixture, 6 or 8 of the lights evenly spread through the shop.
I'm pretty unfamiliar with all the available lighting choices out there. What's the difference between a high bay and a low bay? Dispersion characteristics? What's an f-bay?Depending on your temperature range I'd go with either T5 or T8 F-bay fixtures. If you put in something without a reflector, he'll be disappointed.
Aint it great to be a designer too?I'm pretty unfamiliar with all the available lighting choices out there. What's the difference between a high bay and a low bay? Dispersion characteristics? What's an f-bay?
The shop will go between 20°f-100° f depending on season. I was under the impression that t5's don't like low temps.
T8's aren't as good for low temps but they have improved them. If you're interested, I'd go to one of the name brand lighting company's web site (Cooper etc.) some of them have lighting calculators and layout tools to get the footcandles you're looking for with a specific fixture.I'm pretty unfamiliar with all the available lighting choices out there. What's the difference between a high bay and a low bay? Dispersion characteristics? What's an f-bay?
That's not a lot of light. I think for a shop we'd shoot for more like 45 footcandles. I think 1 footcandle =10.76 lumensSo looking into osha rules for warehouse illumination I found that they require 5 lumens per square foot. That would be 8 32 watt t8 lamps (2800 lumens per) before any calculation for loss. Is this right? I don't have any reference for what 5 lumens per square foot would be, sounds pretty dark to me though.
Are those practical considering they use 4 times the power of a 2 lamp t8? How many lumens do they put out?250 watt metal halide fixtures.
At 12' above the floor? No way manmbednarik said:T5ho 4 lamp fixtures with white reflectors. Lay it out with lithonia or coopers website. Usually a supply house will lay it out for you if you buy the fixtures from them. T5hos usually have a min start temp of -20f.
