I use them at work all the time.B4T said:I have a customer who has a 1960's line voltage thermostat... They want a "modern clock stat".. anyone come across one that fits a standard gem box..
I had to run new stat lines and put them in a better location.. the customer also wanted more of a selection for the stats...What did you end up using?
So you're using a relay instead?I had to run new stat lines and put them in a better location.. the customer also wanted more of a selection for the stats...
I put in (2) cheap LV stats till THEY find something they like...
Yes... used a TACO 2- zone relay..So you're using a relay instead?
The circulator relays? :blink:Yes... used a TACO 2- zone relay..
Yes... I have always used that brand when doing LV stats...The circulator relays? :blink:
I guess I'm missing something here - do the relays control line voltage baseboards? If so, I didn't think the Taco relays had the current rating for that.Yes... I have always used that brand when doing LV stats...
I started with line voltage stat to control BB heat.. customer wanted LV clock stats... so I put in a TACO relay...I guess I'm missing something here - do the relays control line voltage baseboards? If so, I didn't think the Taco relays had the current rating for that.
Ok...how much current are you running through the Taco relay? I thought they were only rated for 10 amps, single pole? :blink:I started with line voltage stat to control BB heat.. customer wanted LV clock stats... so I put in a TACO relay...
I think you are really confused... :blink::blink:Ok...how much current are you running through the Taco relay? I thought they were only rated for 10 amps, single pole? :blink:
