1 - 6 of 6 Posts
Please tell me if any of my calculation is off
These are the loads in a 120/208V panel board
Phase A : 15 800 W
Phase B : 15 200 W
Phase C : 16 400 W
I take the highest value for calculation purpose
16 400 W x 3 = 49 200 W / 0.80 (Power Factor) = 61 500 VA
61 500 VA / (208V x 1.732) = 170.7A
The wire has to be derated therefore, 170.7A x 1.25 = 213.4A
According to CEC (I presume it’s the same with the NEC) I need 0000 AWG wire
Would you use a 200A disconnect with 200A fuses
or
A 400A disconnect with 225A fuses?
Phase A : 15 800 W
Phase B : 15 200 W
Phase C : 16 400 W
or
If you're derating the wire your number should be lower not higher.
I would use a 200 amp disconnect amusing you're using 4/0 al...
1 - 6 of 6 Posts
