A few thoughts,
1. For starters, anyway the cards fall (no pun intended) I hope you lads did better than I.
2. I'm curious to know how the rankings are made. As far as I know this quarterly testing thing is new, and so how do they rank the April test takers against (let's just say) the July test takers. Are the rankings for each class start date. In other words, will April test takers be ranked for a July class, and will July test takers be ranked for an October class, and so on?
3. I'm curious to know if you boys put in for just A cards or C cards or A and C cards. I put in for both. I ranked much higher on C, and I wonder if that's because no one tested for C or if my "aptitude" is better suited for C, I doubt it.
4. I know it's based on demand, but anyone have a clue as to a common class size and to what degree 134 is taking on.
Once again, best of luck lads.
