more info, one solution
Hello all: The conduit is PVC 3/4" SCH 40 electrical, a total run of 75' in several sections. There is no GFI and I am testing directly at the wire ends disconnected from the connectors and system. It was installed poorly, with many sharp bends and a U turn. No junction boxes or pull elbows to access it. It will be very hard to easily pull a new wire. If I know the fault location even approximately, I can localize the area and save time. One solution may be a milliohm meter, measure the loop resistance at each of the ends and calculate the resistance, assuming the fault is a dead short. I am open to your further ideas! With Kind Regards, Jon
