1 - 20 of 77 Posts
Today's transformer install. Hopefully it doesn't vibrate right off the wall and go downtown like the last one
Automotive exterior Handle Room Door handle Metal
Machine Product Machine tool Tool Milling
Room Architecture Machine
Electrical Simpleton
I thought the code required flex... :whistling2:
Pete
EBFD6 said:
How would you have done it? Back to back emt connectors? That would look like sh!t. A threaded nipple is the right choice for this application.
I agree, I would have probably used hard pipe all the way. I like your solution better.
Did you install the last one?
Of course it vibrated off the wall.
Just like that one will.
You have zero isolation there. No springs, no flex.
Does that job have specs?
I don't think I have read one that doesn't require springs and flex
Discussion Starter · #11 ·
360max said:
why did you switch to rigid?
Because I can cut and thread rigid into any length I want and two EMT fittings that are 5" away from each other looks like slop
Discussion Starter · #12 ·
cdslotz said:
Did you install the last one? Of course it vibrated off the wall. Just like that one will. You have zero isolation there. No springs, no flex. Does that job have specs? I don't think I have read one that doesn't require springs and flex
Lol. That made my day
Hmmm.. really?
I don't know if you're serious. This is done all the time. Should be fine
question, does the transformer have rubber mounts inside that core sits on?:whistling2:
Donuts > Fried Eggs
Burrito, Cherry coke, pennies, etc.
I woulda used those combination conduit bodies with the set screws for EMT. :brows:
Or maybe even worse an arlington anybody. :brows::brows:
1 - 20 of 77 Posts
