1 - 9 of 9 Posts
I do a lot of residential work but I want to branch off into at and I need a course on motors (3 phase) and starters. All the courses in the area are union run so I can't get in them. Anyone know of any good books I can read?
Sent from my XT901 using Tapatalk
Coffee drinking member
h.watts electric said:
The link is not working Sent from my XT901 using Tapatalk
Try it again by pasting the link in your browser.
It's a PDF and takes a minute.
I also posted it here a couple years ago. You could search for it. But if you hit google and search for
-- square d wiring diagram book PDF --
It should pop up with the same link I posted.
Seems ET is goofing it up.
Electric Motor Control by Stephen L. Herman. Pretty dry reading but a good overview of all the common components.
1 - 9 of 9 Posts
