I found this thing online, then I also found this company spamming on other sites.
To condense pages of their marketing sham, the retrofit kit is basically a daughter-board that hangs from existing fixture shell.
The daughter-board has its own reflector and an integral ballast with 0.95BF. It fits into modified exiting medium bi-pin socket and a T5 normal output lamp is installed into the adapter.
The fixture itself must be rewired so that one end is neutral and the other end is hot with a fuse box in middle.
Instruction:
Brochure: (ignore their marketing blah blah since its full of wrong)
http://lumiversal.com/upload/LUM_LCM_Brochures_0310.pdf
Latest T5 lamps are more efficient than the crappiest T8/T12, but it's on par with the latest T8 and T12. They're certainly more expensive than latest T8 lamps. T8 lamps have a longer life under same conditions and they're equally efficient. Normal T5 lamps are basically built on the same technology so there's really nothing special. The F54T5/HO works better in extreme temperature only because they use amalgam instead of pure mercury.
I have no idea what this gimmick costs, but I don't think they're cheap.
They play the middleman for T5 lamps to be used in their fixtures, clerical work(do your incentives paperwork) and
provide financing service... :001_huh:
I think its mostly a marketing gimmick. The fixture modification is more work than a normal ballast change out. If you've an old magnetic T12 system, then you should just change out to NEMA Premium T8 ballasts that meet the rebate requirements and high efficacy lamps (3100lm 32W).
If you've already got a T8 electronic ballast system,then you can just CLEAN the fixture in addition to changing the lamps to premium efficacy 25, 28 or 30W lamps. The 30W provides the same output. The 25 & 28W lamps reduces output and power use if the current system provides more light than necessary.
Instruction:
