1 - 6 of 6 Posts
Probably need to read up on all the categories. The company probably uses 3 as a target, and wants to know you understand stuff like safety relays or redundancies.
Sent from my SM-G965U using Tapatalk
Discussion Starter #5
Yes, I was aware of machine safety but was not aware of categories.
so far what I dig out. is...
CATEGORY 1: “A single fault can lead to the loss of safety function.”
Example: A door switch contact failing in the closed position resulting in the machine continuing to run
CATEGORY 2: “A single fault can lead to the loss of safety function and the loss of safety function shall be detected.”
Example: A door switch contact failing in the closed position resulting in the machine continuing to run but a second door switch triggers a warning light.
CATEGORY 3: “A single fault does not lead to the loss of safety function.”
Example: a door switch contact failing in the closed position but a second door switch alerts a safe controller which shuts down the machine. The distinguishing detail from Category 4 is that there can be multiple switches used on each channel of the controller.
CATEGORY 4: “An accumulation of safety faults does not lead to the loss of safety function.”
still digging out more...
What category is "spontaneous, rapid, self disassembly"?
Reactions: gpop
1 - 6 of 6 Posts
