Obviously not listed :whistling2:
My wife found some decorative tin stars at the craft store and wanted to make them into accent lights to put outside our garage in place of the existing lantern lights. So I got some miscellaneous parts and rigged up a demo in my workshop.
They turned out pretty cool!
I got a round PVC blank, drilled a hole in it, and mounted a medium to candelabra base adapter through it. On the backside I screwed in a pre-wired rubber coated medium base screw shell which will attach to the existing jbox. Then I stuck a 7 watt night light bulb and hung the star in front of it.
It'll look cool on the garage
