I find myself in new territory again. While the physical work is no problem, I need to provide a load calc for this new service.
Power source is 120/208 to a 200 amp meter which will feed a 200 amp MB outdoor panel. Here is where im unsure of how to calculate. The panel will be feeding receptacles for the boats. 6-30 amp 3 wire and 8-standard 20 amp gfci outlets.
I know a dryer is 5000 watts and a fridge is 1200 watts and so on.
What do I use as a measure for the 30 amp boat receptacles?
Thanks for any code ref you can provide
