Easiest thing to check for would be current on the grounding conductors in the dock electrical in both Ac and Dc. Another issue could be a chemical in the water in that area.
You could check the usage rate on the anodes if you measures the current from the anode to your boat. You could also check the voltage impressed on the boat by the galvanic system. I don’t know what the ideal voltage is for whatever metal your boat is but steel should be lower than -.8 volts to a half cell.
Oh and the depletion of the zinc anode is what provides your cathodic protection. Galvanic isolation is a coating that prevents erosion from galvanic currents not anodes.
