1 - 20 of 22 Posts
Max bend radius or minimum bend radius? Or are you asking how many degrees you could put in 10"? Does this ever get old for you? You need a new character.
I never said 10". Just a short piece. I'll rephrase, if you bend a conduit more than it's supposed to be bent and you deform it slightly is that ok? So, say your 3/4" is bent so much that it looses partial volume?
Discussion Starter · #17 ·
Not sure why you ever ask anyone anything. You do it the Cletus way. The right way, the wrong way, and the Cletus way. You try to get people upset on the forum by posting it your way.:001_huh:
you got it
Cletis said:
What's the maximum bend radius on a 3/4" conduit in a 10 inch radius per nec you could make on say a piece of emt or pvc ? 90 degrees, 110 degrees, 180 degrees ??
this is what you said. It makes no sense and is not worthy of an intelligent answer. I have always told my apprentices that there is no such thing as a stupid question. I have been proven wrong.
1 - 20 of 22 Posts
