Status
Not open for further replies.
1 - 4 of 4 Posts
I am getting ready to replace some outlets in my pole barn, the original circuits were run in Romex and I am planing on using MC Cable to replace them (the field mice chewed the original ... I know thats a whole different forum for that problem but its the way I bought the place and already got a cat :) So my main concern is the routing of the wiring I am bring in a new 200 amp service and meter with proper grounding, if the metal casing (using Aluminum clad) of the wiring touches the building is it considered a double ground and a safety concern? The original Romex was looped over the outside of 4x6 posts 9 feet height on the original pull if I route the new wiring the same way it will contact the building, should I drill the 4x6 posts and run the MC thur each one I was concerned about weaking the structure as well. I appreciate the input :)
.....there is absolutely no reason why MC cable jacket can't come in contact with building steel.
In fact it's intentionally done at least once.
Electrical Simpleton
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to www.DIYChatroom.com/register.php/
1 - 4 of 4 Posts
Status
