How about a vacuum and balloon?what is the best way to get true tape from point to point on a long runs of conduit , does anyone have trouble with it breaking half way ? looking for solutions what about leaving it in the conduit and it will not come out after one day ?![]()
we have runs that are 289feet to 300 feet long cant run a fish tape , and after you pull in the true tape we pull it back out to save money on the cost of the tape just and leave a string in the pipe to pull in the 1/4 rope to pull in the larger rope but if we leave the true tape in over nite it does not come out the next day it sticks ?just thougth someone had the same problem and could tell us how they do there measuring on long lengths . but i get tried of hours wasted . my company cant buy rolls of true tape it cost 45 dollars a roll we would spend lots as we have hundreds of conduits to measure on one job ?what is the best way to get true tape from point to point on a long runs of conduit , does anyone have trouble with it breaking half way ? looking for solutions what about leaving it in the conduit and it will not come out after one day ?![]()
we actually use pieces of plastic bags from convenience stores...A vacuum, an air compressor and a sandwich baggie.
until we use it to pull in the larger rope needed to pull the wire.Yep. I agree. Do they leave "true tape" in the pipe?
yes, yes, yes and etc:laughing:![]()
Conduit Measuring Tape ...............................(Not actual size or to scale...LMAO)
Blow/suck/pull it in however ...just get it in.
We leave it IN the conduit until we are ready to pull the run for a couple of reasons:
1 - it's cheap
2 - it can be used to drag a heavier line through the pipe if need be
3 - you can check that the run hasn't been broken/jammed BEFORE you start the real pull
4 - etc
god damn crack addict salesmen...how in the heck is a laser tape gonna measure through 3 - 90's?Get a laser tape.
the plastic bag from the convenience store will work on runs with SS fittings (without taping them) for upto about 200' or so...yes, this is from experience...Also, most of our long runs are in plenum ceilings which require compression fittings. Never seem to lose much vacuum suction with those.
true tape costs <$0.02/foot...that is $6 for a 300 foot run...how much labor $ are spent pulling the true tape, then pulling it out and pulling in pulling string that costs about $0.01/ft?we have runs that are 289feet to 300 feet long cant run a fish tape , and after you pull in the true tape we pull it back out to save money on the cost of the tape just and leave a string in the pipe to pull in the 1/4 rope to pull in the larger rope but if we leave the true tape in over nite it does not come out the next day it sticks ?just thougth someone had the same problem and could tell us how they do there measuring on long lengths .iam just a helper but i get tried of hours wasted . my company cant buy rolls of true tape it cost 45 dollars a roll we would spend lots as we have hundreds of conduits to measure on one job ?
Get a laser tape.
I like mice :thumbsup:Celtic, I've never seen the man pons. We've always used the 'mice'. Little nerf cylinder with eye hooks at either end and sized for the conduit.
IMHO...... we pull it back out to save money on the cost of the tape just
.i am just a helper but i get tried of hours wasted .
