Ok, took out the trash so we can move on.
Anyways, in general, after a fire you are going to deal with three major types of damage to electrical systems and equipment:
1: Heat (duh.) Even in the areas not directly involved in the fire, the radiant (or conducted) heat can be high enough to melt or compromise insulation on wiring and equipment. A megger has good chances of detecting this. BUT if the insulation on cables like NM is completely burned away, and the conductors are in "free air" or not touching each other, a damaged cable can still pass a megger inspection. IMHO ALL NM and MC/AC cables in a building involved in a fire should be replaced, I wouldn't waste the time testing them. Wiring in conduits or raceways, where the conduits or raceways can be proven to be undamaged, can be meggered and replaced only as needed.
2: Smoke damage. This can happen throughout an entire building, even from a relatively small fire. Smoke particles and residue are highly conductive (and corrosive) so ALL traces of smoke residue must be thoroughly cleaned from all wiring and equipment with solvents safe for the insulating materials used. Water and or liquid soap is NOT an acceptable cleaning agent IMHO as they will simply trigger the corrosive properties of the smoke particles. Devices such as switches, receptacles, fixtures and ALL circuit breakers exposed to smoke at all should (must) be replaced. Bolted pressure switches and breakers designed to be rebuilt can in most cases be rebuilt rather than replaced.
3: Water damage. Anything that got wet during a fire must be replaced. (Especially if it was energized when it got wet.) The water will be highly corrosive (see #2 above) and will rapidly cause rust or corrosion damage to anything it gets into. Cleaning, even with approved solvents, may not prevent future corrosion damage.
In short, IMHO it is much better to replace anything involved or near a fire, no matter what the size of the fire. (Of course, I would not suggest rewiring an entire house if there was only a small fire like a trash can fire in one room...BUT ALL devices in that room and any other that show visible smoke residue should be replaced. And any wiring in the immediate room should be visually inspected, and yes I mean open the walls in that room.)
It really depends on a lot of factors, but I would rather err on the side of caution than overlook something and have to come back for another fire repair....
