We have wired up 30 lights on 3 different circuits and before we powered them up the client asked us to megger the lighting circuits. To my understanding you are not able to megger from line to neutral through the fixture as you will damage the ballast. One of the journeyman on the crew pointed out that if you megger with the line and neutral together and to ground that you will not damage the ballast be because there is no potential between ballast leads. Does anyone out there have experience with this?
