1 - 7 of 7 Posts
A restaurant heat coil part failed in a fried food holding station FFHS27A-C1G11 just after the 1 yr warranty ended.
This shows 208 on name plate but was installed with 240 with ground vs 3 leg supply. I replaced the $400 heater part and it worked for a day...so now wondering why it failed and asking if 240 can be used in this 208 equipment.
Thanks
Discussion Starter #3
Basic ...here it is on partstown:
Delfield 2198638 HEATER,AIR,4500W,208V
List Price: $ 396.00
Mfr Part #: 2198638
Parts Town Part #: DEL2198638
Coffee drinking member
Welcome to ET
Please finish filling out your profile.
How long have you worked in this restaurant
Scada Supervisor
Quick answer is no. Depends on cycle time on how long it lasts, if only a little heat is needed it will work for awhile, but if it is heating all the time it will not last long.
Reactions: samgregger
P = E X E / R or Power = voltage squared divided by the resistance. After doing the math you are probably causing the element to produce 5,100 watts which might be too hot for the use.
1 - 7 of 7 Posts
