Was at work today and had a 50a disco right off the meter with some wires that where damaged. So I was going to pull the meter and go on with business. When I tried to remove the cover it wasn't one I've seen before all it had is a hollow circle about 1/2" no locks or tags. Anybody seen such a cover and know how to remove it? Thanx
There is usually a lever that is spring loaded and the tip of it is at the top of the meter cutout, I believe on the right side. Sometimes you have to use a screwdriver to lift it up if it's been in there a while.
Just lift up on it and pull the cover at the same time.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Electrician Talk
