He should re do the video because you don't like the tool? I have has zero issues with my strippers. They cut and strip the wire fine, better then any other strippers I've owned.
No, he should re-do the vid and tell it like it is, unless his tool can cut and strip a ballast wire like a normal pair of strippers. But i asked him that and he never replied.
I ream PVC with my thumb. Really. Try it. Now if he wants to say the thing reams then he should do EMT or rigid, or metal something. Then for a test run his finger around the EMT he just reamed. The teeth on the reamer are
90 degrees out of whack to ream anything.
It's a nice tool that's why I bought it nearly a year ago. I've posted my review on it then and above. Both him and the company cannot say I'm full of it... whereas I can say they are omitting a couple of things it doesn't do.
Look at my pic. Yours different? Did they fix the cutter? When is the last time you seen a cutter that would let the wire completely miss it? Did they fix their so called reamer? Have you reamed a standard piece of hacksaw cut EMT? Does it work?
No, not my opinion. Fact. And I posted pics to show it. This is on a pair I purchased in February 2013, - 10 months ago. They have had time to re-do the dies. I just asked if they had. I dated my pic. My original post is dated.
I'm waiting.
Edit: They did not think this tool out. Well they did it's nice, it just wasn't tested. I tested it for them. It would not have gone into production had I been involved. It would have been re-designed so those two items worked as advertised.
Edit 2: I did not try the reamer. I bought the tool, changed two ballasts with it, returned it. It was in my possession less than 24 hours. My eyes are telling me it won't ream. Could be wrong tho.
Edit 3: Crap, just thought of something. You could use the tool like a file on 2 inch conduit. So maybe it does ream. I'll take that part back I guess. Use my Channellocks as usual on 1/2, 3/4, 1" EMT.
