What goes in gotta come out. What a backward concept. :001_huh:
Many have heard that snow does not melt because LEDs are "so energy efficient". Along with that was a misconception that LEDs run cool and give off almost no heat.
http://www.engadget.com/2009/12/17/led-traffic-lights-dont-melt-snow-do-cause-accidents/
First, traffic lights is a different ball game from general lighting. LED is one of the most efficacious technology for producing highly saturated colors such as those sought after for traffic lights.
Incandescent traffic lights use colored glass filter to create the desired color and absorbs infrared as well, which warms up the lens.
In all electrical appliances, thermal dissipation into the room is equal to electrical input into the fixture, minus the radiant energy escaping out the window which is a drop in the bucket.
15W LED and 15W incandescent lamp takes in 15 watts of electrical power, and simultaneously rejects 15 watts in the form of conducted and radiant energy. Though LEDs produce more lumens, the overwhelming majority is rejected as heat (same goes for HIDs and fluorescent) Incandescent lamps reject heat through invisible infrared radiation. LEDs dissipate heat almost solely through conduction, therefore it gets hotter at the fixture.
LEDs are not much different from SCRs, transistors, CPUs,etc. They do not like heat and depend almost entirely on conduction by heat sink for cooling since they can't run at high enough temperatures to reject heat by infrared.
LED lighting for common applications in air conditioned spaces use MASSIVE heatsink(comparatively for their wattage). For special applications such as color changing stage spot lights, they're FAN COOLED, like computers.
You could trap a 20W halogen lamp in a beer bottle, pull a vacuum around it and it can still dissipate heat. The radiated infrared energy will induce heating on the brown bottle and whats not absorbed will escape.
Do the same with a 20W LED bulb and it will get hot until its broken or its glowing cherry red.
Even fluorescent lamps reject 37% of energy as infrared (IESNA Lighting Handbook)
Most LED lamps will not survive enclosed luminaires, commonly found for outdoor or other applications requiring good water resistance.
LED marketing boasts its performance in bone chilling weather, but lighting is used in applications where it gets hot too.
Externally heatsinked LED fixtures can still have trouble maintaining specification lumens-watt under actual application, such as 55C ambient in unconditioned high-bay mount warehouse lighting. No amount of cooling will bring the heat sink below 55C. Amalgam CFLs(induction also), HIDs and induction can handle such applications without an issue.
13W LED lamp after a few hours in an enclosed fixture
Oops, melt down....
It got hotter than 212F
