Status
Not open for further replies.
1 - 3 of 3 Posts
I have my own separate power pole with overhead line coming from nyseg.
It has a meter box and a 50 amp 220v rv outlet breaker box.
The neutral bus bar in the breaker box broke off. Can this be replaced individually?
It looks to be insulated, I found a non-insulated one at lowes which would fit. Can it be
non-insulated?
There is aluminum wire like #2 coming from the nyseg pole through the meter into the box.
The electricians say they cant replace just the bus bar or the box, they
want to replace the whole line from the nyseg pole, meter, and box which costs a lot.
What is a fair price for doing that?
Also some of them want to replace the pole since it leans a bit.
How much can a pole lean? It was installed this way 20+ years ago so I dont think its
falling over any time soon.
This is in NY south of rochester.
Hackenschmidt
This site is intended for electricians and professionals in related industries, so this question will be locked soon. Bring your question to diychatroom.com and you should get some help. I also recommend you find a way to post some pictures there, you'll get much better responses.
Reactions: 460 Delta
EC
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.If you are permitted by law in your area to do your own electrical work, please sign up at our sister site, www.DIYChatroom.com where many of our professionals are also members and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to Register
1 - 3 of 3 Posts
Status
