Wire all the motion detectors to a multi-pole contactor, like an ASCO.
No, a multi-pole contactor is definitely not real.If this is a real thing and not like that retro encabulator,thank you. I'll take a look.
@Kawicrash thanks for mentioning the load. I had missed that part when I trippped up on "breacker" which inspired me to check OP's profile to see if he's a bona fide sparky.How many lights is several? Could you use LED lamps to reduce the load? What type of fixtures are they now? You say 500W, are they halogen T3? Terrible lifespan.
A multi-pole contactor or two, or however many you need with the sensors paralleled to the coils seems simple enough if the power wiring is all accessible at a common location.
Good point ! You'd just use a regular cabulator contactor :biggrin:Retros are not used for new builds.
I remember seeing one with all 4 poles on it.No, a multi-pole contactor is definitely not real.
There is no regular encabulator, the original is a turboencabulator.Good point ! You'd just use a regular cabulator contactor :biggrin:
I stand corrected ... I thought the turboencabulator was just faster :biggrin:There is no regular encabulator, the original is a turboencabulator.
