I have a 3HP 3phase 230/460V motor for a through the wall exhaust fan.
Whoever installed the motor they just connected to the switch(L1,L2,'L3 to T1,T2,T3)
Under the diagram it says "Use a manual momentary start switch only".
Now I tested the 3 wires on the LINES and I have a 220v and a neutral
When I turn on it doesn't work... If the one that aperently is the neutral I ground it it works...
But I think is on a low voltage diagram because the motor stars really slow...
IM NOT A MOTOR MAN,
It comes from timer to the motor.....
Any suggestion? How can I make it work... Properly?
IM NOT A MOTOR MAN,
