Those motor specs are wrong; you cannot have a higher voltage for the delta connection. Wye is always higher.
If the wye connection is for 660 volts (I strongly suspect it is), then running it on 380 will cause it to produce roughly 1/3 of its rated HP.
If the load is such that the FLA for the wye connection (Higher voltage) is not exceeded, it'll be ok.
