1 - 7 of 7 Posts
Hello,
I have a query concerning a Motor Control Center (MCC)feeding 3-phase 575V motor loads.
Do MCC usually have a feature to automatically trip the circuit feeding 3-phase motors, if a phase is lost? OR would the motor still run off two phases, overload and then eventually burn out?
Thank you.
Most of the MCC I've seen and put together don't have them. I see them on the substations we use up stream from the Motor Control Centers.
ABB and Eaton make decent phase monitors which as mentioned before can be installed.
Thank you all for your inputs. Integrating phase loss relay into the existing MCC seems to be a straight forward solution to mitigate this issue, because replacing motors when they burn out due to phase loss is much more expensive endeavor.
Senile Member
And if not, some of the cheapest (cost not quality) 3 phase line monitor relays can be purchased at AC supply stores, like the Carrier store. Buying the same items from electrical suppliers seems to double the cost.
Reactions: daks
1 - 7 of 7 Posts
