I'm doing the MSHA required ground continuity test at a local rock crushing plant, likely more than 100 motors from 2 - 400HP. My connection to the ground bus at the MCC was right below a size 2 NEMA starter which was labelled '40HP Tunnel Belt'.
The bucket didn't look like a size 3 so I opened it up and sure enough, it was a size 2 feeding an actual 40HP motor. I've done work at this plant for 6 years and I know for a fact that this starter and motor have been this way for at least that long.
So, being the curious person that I am, during my ground check, I wrote down the HP of every motor and looked at the starter size when I cleaned the buckets.
4 - size 1 (10HP max) controlling 15HP motors. 2 - size 2 (25HP max) controlling 30HP motors, and 1 controlling a 40HP. Everything else was ok.
So here's my question, a size 1 starter is rated at 27 amps and can control a 7 1/2HP motor on 208 or 230 but only a 10HP on 460. Why? It seems to me that it could (and some certainly do....) control a 15HP on 460.
Same with a size 2. 45 amps and 15HP @ 230 volts but only 25HP @ 460. It seems like it could handle a 30HP.
Size 4 and larger, the 460 HP is 2X the 230 HP. This makes sense, the smaller sizes do not.
I can't help but wonder just exactly how these ratings came to be, they don't make much sense.
Anyone else see starters controlling motors larger than their ratings?
