1 - 3 of 3 Posts
Hi,
I have following motor nameplate
This is 10HP 480v 3ph motor upgraded from 5HP motor
I noticed the triangle symbol on leg2
Does this triangle mean anything?? because i've never seen this type of nameplate before... but i wired it as regular motors..
thanks
Hi,
thanks
welcome to the forum
did you post a pic? for some reason I cant view it
anyway a triangle symbol on any motor name plate means it should be Delta connected. but on leg two only? I dnt know what that means.
so how did you connect it?
My guess is that there's another drawing that shows the wiring scheme for double-delta/part winding starting (or, start connection omitted and it's just the low-voltage run half of double-delta). The drawing you used is the "regular" connection style (delta).
1 - 3 of 3 Posts
