When I turn the vfd to 68% the motor makes this loud humming noise. Sounds like it's vibrating. If I go past 68% on the vfd. The noise stops and the motor sounds great. Any ideas?
50hp
3 phase 480v
60hz
Drives a fan. It makes the noise with no blades attached.oldtimer said:Just curious ! What does it drive ? Does it act like that when there is no load ?
Why would there be a centrifugal switch in a 3 phase motor?:001_huh:I hooked up a VFD for my senior project in tech, ran a 3 phase 208 motor, motor whined until a certain speed was reached when the centrifugal switch kicks out.
Do you mean that the sine wave is distorted?Lone Crapshooter said:The voltage going into the motor is nonsineusotial in it's shape.That causes the windings to vibrate a odd frequencies. What you are hearing is normally heard on motors that are powered by a drive. LC
You ruin all the fun.Why would there be a centrifugal switch in a 3 phase motor?:001_huh:
You probably hit a resonant frequency. Hopefully it will be a non-issue with the blade on.View attachment 32002
50hp
3 phase 480v
60hz
Bingo. Most machines have at least one if not multiple resonant frequencies. It means that there is some sort of mechanical speed at which vibrations in different parts interact with each other and amplify to where they are noticable, maybe even dangerous. Most of the time these are lost in the flood of other vibrations and you can't tell they are there. When you run an uncoupled motor, nothing else is vibrating so you can notice it.You probably hit a resonant frequency. Hopefully it will be a non-issue with the blade on.
