Has anyone else run into this problem? A customer asks for a receptacle and a tv bracket to be mounted on the wall. No problem on inside walls but: ok outside walls where the wall is block, furring strips and drywall you have a bit of a dillema. The lags that come with the mounting will split the furring strips and won't enter the block. Not to mention tap cons won't hold the weight of most of these TVs. So, suggestions? I've avoided placing the tv on these outside walls for the most part, but someday that won't work. It'll have to go where the customer needs it.
