Recently I noticed that my garage door was partially open after I thought that I had closed it. When I tried to close it again (or open) the door opener wouldn't work. I could not manually turn the opener light on either. So, I thought it was the breaker. I went down stairs and it was not tripped. I went back into the garage and tried other outlets and much to my surprise, they worked. All of sudden, the opener light came on and power was restored. This has been happening now for a couple of days. I bought one of those idiot test plugs (with three lights). While everything seemed ok again, I plugged it into the socket where the garage door opener was plugged in. According to the lights on the tester, every thing was good. The next time it went out, I got the tester again and plugged it in. Now it says the Hot and Ground are reversed. A little while later, power restored itself again and the circuit is just fine.
What the heck is going on?
I have the garage door opener working off of an extension cord now from one of those good sockets.
Obviously the wire can't be reversing themselves and then again fixing themselves.
Got any ideas??
Bill
Got any ideas??
Bill
