1 - 18 of 18 Posts
Looks like a Halo or possibly a Juno. I think Halo and looks like a 2 circuit track
animal lover /rat bastard
I can't tell one from the other, but we installed some called Nordic Light recently that looked like that. it was 3 phase though.
It may also be progress, or the brands from Lowes or Home Depot but since it is 2 circuit I bet not from the Big Box
3 ckt? pretty neat...
this is a 1 circuit track with 2 ckt fittings...i wasn't onsite, so I going by the pics and the tech's info..
it's this junk. but doesn't look like what you got
http://eu.nordiclight.com/content/products/default.aspx#categoryID=2#productID=45
all these big retailers get the crap drop shipped from china and then when the parts aren't there they want to screw you out of the extra labor to work around islands and merchandise and all the other horse hockey, like it's your fault. I'm sick of it. that stuff above really isn't that crappy. except when some helpers jam the heads in the wrong way.
RIP 1959-2015
The fitting is a center feed fitting. There are jumpers that go from one side to the other and you bring in the switched circuit. You could remove the jumpers and bring in two switched circuits.
Here is a Halo one
That fitting is actually called a straight connector. They make a mini one but you cannot feed the track with those.
I own stock in FotoMat!
Here is a Halo one
It's also a coupler / elbow connector. It can be turned to any angle up to 90° and only needs the proper cover.
Electron Pathway Engineer
Those end caps look like wire molds stuff.
It also resembles europhase connections as well.
Like 480 said, but check inside the bulb cup for the sticker.
It is Halo.
You can see the groove running the length on the neutral side.
HD sells a knock off under the name Hampton Bay
It is Halo.
That's right and Lowes sells another knock off made by Portfolio. They are identical except the color on Portfolio is a bit off white compared to halo but 1/3 the price
1 - 18 of 18 Posts
