1 - 18 of 18 Posts
So i did a flush mount panel swap today and everything was going well until I put the new panel up to the wall. Crap, the cavity is too narrow by 3/8 of an inch or so. The Sawzall is missing. Does a crappy job anyway.
I had to resort to a 1 1/2" spade bit up one side of the cavity. Looked like the moon when I was done. But the swap turned out great, and the boss is happy.
Do any of you have an efficient method for widening such a space? I was thinking about a planer. Any ideas other than tearing out the wall?
I've run into that a few times. I don't remember what I did to remedy the situation but it all worked out just fine.
I think I just cut out the entire stud and screwed it to the side of the can or something like that. Very incidental to the whole job.
felonious smile.
The sawzall aimed on 45° angles away from panel outline work for me every time.
...and save yourself 4 cents in materials and ninety seconds of your time.
I think the old panel was 14" wide, made for 2" wide 2x4s, new ones are 14-1/2" made to fit between studs that are 1-1/2".
I plan for it on older houses. Sometimes they just scab a piece on next to the panel to hold it in place. I like finding those. Otherwise, I cut out the whole stud and move it over enough to fit the new one in place and screw it to the drywall or whatever the finish is.
Using the spade/paddle bit as a router is fine. I've done it a hundred times.
It's quick, easy and looks great when the panel is installed and covered up.
IBEW L.U. 1852
While I don't do much resi any more....I have run into this once or twice before. I always liked using a flat bottomed forstener bit.
I usually used my 3.5" forstener and sank it into the 2"x4" as many times as necessary.
I use a large chisel, something like 1-1/2". Score the top and bottom of the stud and remove material until the box fits.
1 - 18 of 18 Posts
