For any guys in the retrofit buisness curious how the new article in 2014 code has been interpreted .... Does this apply to LEDs for gas station canopies under the metal roofing?
(F) Luminaires Installed in or Under Roof Decking. Luminaries installed in exposed or concealed locations under metal-corrugated sheet roof decking shall be installed and supported so there is not less than 38 mm (11?2 in.) measured
from the lowest surface of the roof decking to the top of the luminaire.
