1 - 14 of 14 Posts
Does NEC allow running multiple 480V 3 Phase Power load conductors in a single conduit instead of running each 3 phase loads conductors in separate conduits?
Sorry !! If my post language is not clear let me try to clarify Does NEC allow running 3 phase feeders of more than one 480V, 3 Phase loads in a single conduit instead of running each load feeders in a separate conduits? Example say for 2 - 50 HP motors running instead of running in 2 separate 1 1/4 inch conduits with 3#4 AWG -each run 6 #4 AWG in say 2 Inch conduit? Hope this is clear.
Power2engineer is online now Report Post
Yes, the only thing limiting it would be conduit fill and de-rating for # of current carrying conductors.
On that load conduit fill would only be like 15-16% (fine) and de-rating wouldn't be an issue with only 6 wires unless you are in a really hot area.
Elechicken!
I think the real question is: is there anything prohibiting it?
Sent from my new phone. Autocorrect may have changed stuff.
Chief Flunky
Field Service Engineer
Those aren’t feeders if they are off the starters. Those are branch circuits. You need to derate for more than 3 current carrying conductors though. It is not uncommon to have a dozen or more circuits in wide cable trays where the derating rules are not so severe.
Seriously? If you have 2 motors, generally, you will need 2 conduits, one to each motor. If you run one conduit, how do you feed 2 motors? Or, how do you come out of 2 motor starters, with one conduit? Unless it's an MCC.
IBEW 6 volts to lightning bolts
I know a guy that knows a guy that might have pulled in 12 sets of 10 and 12 sets of 12 and half a dozen green ones in a 2".
Haha like all those panels I’ve seen with a 2” conduit up to a pull can with 42 MC/BX connectors in it
1 - 14 of 14 Posts
