1 - 20 of 62 Posts
Member
do you guys think having the nec as the state law (it is in my state) but there being little if any enforcement of the code unless an accident happens, helps or hurts good contractors and or electricians.
I fair much better in places that have NEC enforcement. My prices have always been higher than the low guy, and I had a good rep with customers and inspectors.
I just ask that the inspector not show any partiality. Don't let something slide with one contractor and nail another one for it.
Member
Discussion Starter #4
it is adopted as state law in ohio, i would guess other places as well. even though i have never been in a building where i haven't found code violations, even new state inspected buildings.
Member
Discussion Starter #5
it just seems it may handicap contractors that care about abiding by the law. especially when it comes to codes that are generally accepted in the industry more as guidelines and in special circumstances not rigidly followed. and also kind of desensitizes people with the code when you see blatant violations passed by state inspectors.
Its adopted here in NJ too, but its not law
Its a code or standard.
Manufacturers would be considered law because they Trump the NEC and AHJ
Texting and Driving
Adopted as a regulation.
Ohio Regulations
Reviewed: 6/8/2017
Board of Building Standards
Regina Hanshaw, Executive Secretary
6606 Tussing Road
P.O. Box 4009
Reynoldsburg, Ohio 43068-9009
Phone: (614) 644-2613
Fax: (614) 644-3147
Faxback: (614) 728-1244
Adopted Code. 2017 National Electrical Code, effective November 1, 2017. (NEC-2014 until said date)
Adoption type. State-wide. Code was adopted by the state and is mandatory for all structures.
At a Glance: Licensing Requirements
Electrical Inspectors? Yes. Exam required: NCPCCI—2A and 2B; or ICC—E1 and E2
Electricians? No
Electrical Contractors? Yes
CE Requirements
State of Ohio requires 30 hours of continuing education courses must be completed and attached before renewal of residential and commercial personnel certification within a two-year period. These include electrical inspectors, residential building official, residential plans examiner, residential building inspector, and residential industrialized unit inspector.
Reciprocates
West Virginia and Kentucky (Contractors only)
For additional licensing information, please contact the state board or local jurisdiction in which you reside.
Very few of the rules we live by in this country are laws.
Its a STANDARD!
The*National Electrical Code*(NEC), or*NFPA 70, is a regionally adoptable standard for the safe installation of*electrical wiring*and equipment in the*United States. It is part of the National Fire Codes series published by the*National Fire Protection Association(NFPA), a private*trade association.[1]*Despite the use of the term "national", it is not a*federal law. It is typically adopted by*statesand municipalities in an effort to standardize their enforcement of safe electrical practices.[2]*In some cases, the NEC is amended, altered and may even be rejected in lieu of regional regulations as voted on by local governing bodies.
The "authority having jurisdiction" inspects for compliance with these minimum standards
States can adopt part or whole of the NEC
or not adopt it at all
Texting and Driving
Its a STANDARD!
Texting and Driving
Curious, if you don't comply with the standard, did you break a law?
Reactions: Wiresmith
It's not a law, so no. You've broken a regulation. The state may have passed a law defining penalties for breaking their regulations.
I think it doesn't matter what anyone calls it, if you don't comply you eventually won't get to play. Semantics.
Only if someone dies....
Code is just a minimum standard to meet which is why most states adopt it, its uniformed and easier than making up thier own.
Im sure we all have had an AHJ go above and beyong code simply because.....he can
He just cant force you to do less than code.
Texting and Driving
Due to some strong willed electricians, our inspectors don't push their opinion.
Common sense can easily replace NEC rules. The NEC is nothing more than a front for manufacturers to push their products. I would much rather be in a place that doesn't enforce the NEC.
1 - 20 of 62 Posts
