NECA Workmanship standard, installment 2
4577 Views 8 Replies 4 Participants Last post by  JohnJ0906
This is the second in a multipart series on NECA 1, "Standard Practices for Good Workmanship in Electrical Contracting". This standard is referenced in the fine print note to NEC 110.12, Mechanical Execution of Work. "Electrical equipment shall be installed in a neat and workmanlike manner." Most of the NECA workmanship standards are common-sense things, but some are interesting. In this series, we will cover the more interesting requirements.
NECA 1, Article 6, Section K:
Covers for outlet boxes shall be of a type
designed, intended and appropriate for the use and
location, and have suitable corrosion protection.
Plastic device plates shall not be used as covers for
surface mounted boxes
This has always been a pet peeve of mine, so I'm glad to see it in the standard. Some people will use regular flush type plastic receptacle covers on surface mounted receptacles in handy boxes. Some furnace guys will put a flush-type switch cover on a box mounted on the surface of a furnace or AHU. Now, I have a leg to stand on when I say I don't like it. The workmanship spec doesn't like it either.
1 - 9 of 9 Posts
THANK YOU! God, how I hate that! I have got to get a copy of that and beat a few people about the head with it!
Sorry, but that is a serious sore spot :censored:
Even a standard device plate on a surface mounted utility box (handy box?). looks lousy and can cut.
Yeah. I try not to use handy boxes, if I can help it. I try to use 4 squares with RS covers. When I use handy boxes, they get regular handy box covers that match the outline of the box and have rounded corners. I see people using plastic plates on GFCI's in handy boxes all the time, because most GFCI's come with a "free" cover in the box.
Marc I prefer 1900 boxes with an RS cover and flattened corners (AS YOU HAVE STATED) the raised corners look like they might fall off the box.
i might use 2 cases of 1900's a year but truck loads of 2100's. i like the added room and not much diff in cost
I know 1900 (4"x4") but what is a 2100? 4 11/16 square?
When most of us are talking about a 1900 box, we are really referring to a 2100 box. The "shallow" 4 squares are about 1-1/4" deep, and are 19.00 cubic inches. Most of us use the "regular" 1-1/2" deep 4 squares, which are 21.00 cubic inches. The "deep" 4 squares are 2-1/8" deep, and are about 30.00 cubic inches. I've never purposely installed a shallow, 1-1/4" deep, 4 square, but I've seen them in old installs.
Ahhhhhhh... I see.:laughing:
1 - 9 of 9 Posts
