Yup, they're right. Your amp clamp meter won't work if you clamp it around both the hot and neutral so you need to figure out a way to just clamp it around the hot. I don't imagine you want to be pulling the receptacles out of their boxes to accomplish this so you will need to buy or build a splitter.
Like this maybe:
http://www.web-tronics.com/opaclinsplit.html
It looks like this one is wound to provide a x10 winding to provide more accurate measurements at low amp draw.
Like this maybe:
