Hi, im an auto electrician. Fairly new to the trade. I am wiring a set of auto-folding mirrors.
The mirrors are wired up so when the ignition is on, they fold out, and when ignition off, they fold in.
Each case they will get constant 12v. Obviously the polarity will be reversed to operate the motor in reverse to fold the mirrors and then polarity changed again so that the motor unfolds. (using DPDT relay for this)
THE PROBLEM:
As the mirrors will be getting constant 12v 24/7, i need some sort of switch or something that cuts the current/voltage when the mirrors are fully folded and unfolded. What can i use?
Before there was something inside that use to click after few seconds when mirrors fully unfolded or folded. I used a multimeter in parralel to the test circuit and it droped when mirrors folding/unfolding and when fully extracted/retracted, after click the voltage went back up. The clicking has stoped, therefore i beleive something has gone bust.
Thanks
THE PROBLEM:
Thanks
