100 amp on 1/0. 425 feet . :no:
How did u come to that conclusion ?That's what I came up with for feeder size, but what about the ground rod?
I think, actully I know, the 6 AWG 'ground' is too small and is a code violtion.So far the best I can figure is 1/0 alumnium, and # 6 for the ground. What do you think?
Likely.Do I need to drive a ground rod?,
:blink:Also the electric fence requires two ground rods so Im a little leary about driving a third for the panel.
First thing you have to do is decide how much current is really going to be needed.Can you guys give me some ideas? Keep in mind that the 1 1/2 pvc was allready installed and I need to wotk around it. Thanks for any help that you can give me. SO 425ft long, 100a, 1 1/2 pvc, and what to do about the grounding???
Based on what? 100 amps of load?1/0 alum will give ya 14 percent vd
Yep. I didn't do the math. The app didBased on what? 100 amps of load?
Load may change in time too may as well do it right the first timeI think, actully I know, the 6 AWG 'ground' is too small and is a code violtion.
250.122 requires the equipment grounding conductor to be increased in size when the other conductors are.
Likely.
The code requires a grounding electrode system at the building.
:blink:
Leary of what?:001_huh:
You need to know this to do a voltage drop calculation. It would be foolish to figure a full 100 amps of load if there is only going to be 40 amps of full load.
I would run CU.. instead of AL.. now for anThe pipe is 1 1/2 and thats what I have to work with. I told the dude to install two 2in runs and thats not what was done.
He still hasn't stated a load , he said 100 amp before but I doubt he can make that work with 1.5 PVCI would run CU.. instead of AL.. now for anfrom BBQ and MTW...
But it is the only way I can see this working for what you need...
Why a 70 amp breaker?:001_huh:Id run it on a 2-2-4-4 URD put it on a 70 amp breaker.
If it costs to much it might not get done at all.Load may change in time too may as well do it right the first time
